Accommodating Older Workers
Maintenance workers tend to age gracefully. This is due in no small part to the physical demands of the job (walking, lifting, etc). Nevertheless, growing older brings some inescapable facts. For example, presbyopia, which is the medical term for when your eyes gradually lose the ability to see things clearly up close; hence, the need for reading glasses.
Age, however, can also bring positive traits. Knowledge and patience, for example, tend to improve as people become older. If you have ever watched experienced maintenance workers handle thorny problems, then you’ve seen such advantages.
To best leverage what aging workers bring to the table, make the job better fit maturing employees. Tips include:
- Provide higher luminosity for area and task lighting.
- Use larger fonts for print and screen.
- When scheduling work, allow for more frequent breaks.
- Keep meetings brief, necessary, and on point.
- Provide low-slung stools where the location might otherwise require bending or stooping to do the work.
- Be sensitive to the fact that older generations began their careers when hearing protection wasn’t taken seriously or required, and they may suffer from permanent hearing loss.
Mark LamendolaMark Lamendola
Related
Young Construction Worker Dreamstime Xxl 78727300
Smiling Construction Worker Dreamstime Xl 66513518
