Speeding Up Access
How much time for a given repair does the technician spend removing and re-installing covers? It’s not just the time involved turning all those screws. In many cases, a flash hazard analysis must be performed, and the correct PPE acquired and used.
The screws don’t just hold the cover in place when everything’s fine, they also hold the cover in place when something goes wrong on the other side. So, you can’t leave screws out. Use electric screwdrivers and look into replacing screws with flip latches.
If your repair includes voltage measurements, an equipment modification can reduce repair time. Bring the test points to a test panel installed outside the access area. Today, you can use a single display that allows you to scroll through all of them.
If the repair calls for a thermographic scan to verify connection replacement quality, replace this step with measuring the conductance across the new connections as you make them. If it’s within tolerance, that connection is not going to show up as hot in the thermographic scan because there’s not enough resistance across the connection to create a hot spot.
Mark LamendolaMark Lamendola
Related
Dreamstime M 76659788
Dreamstime M 41543526
