Code Quiz
Is it permissible for a qualified person who services and maintains the facility to "peel out" a power cable from a cable tray and run it down the inside portion of an H beam to a piece equipment? The cable is properly supported as it runs down the ...
Is it permissible for a qualified person who services and maintains the facility to "peel out" a power cable from a cable tray and run it down the inside portion of an H beam to a piece equipment? The cable is properly supported as it runs down the column to the equipment, and it's protected by the inside portion of the H beam. Keep in mind that although the cable is unsupported for 5 feet at both ends of the installation, it's properly supported.
A) Yes, but only if the power cable is installed in RMC
B) Yes, if the power cable is TC-ER rated, properly protected from physical damage, and meets all of the requirements of 336.10(7)
C) Yes, but only if the cable is installed in a channel or tray
D) Either A or C
Answer: B)
Per a 2005 change, 336.10(7) was revised to allow the installation of TC-ER rated cable when meeting all of the requirements of this section.
Related
ID 331482540 © Bekir Ugur | Dreamstime.com
dreamstime_xxl_331482540
Photo 160774794 © Ognyan Chobanov | Dreamstime.com
colorful quiz notes
