Code Q&A: Disconnect Rules for Fixed Electric Space-Heating Equipment
Based on the 2017 NEC.
Q. What is the Code rule regarding disconnects for fixed electric space-heating equipment?
A. Means must be provided to simultaneously disconnect the heater, motor controller, and supplementary overcurrent protection devices of all fixed electric space-heating equipment from all ungrounded conductors [Sec. 424.19].
Heating equipment without supplementary overcurrent protection ― For fixed electric space-heating equipment, the branch-circuit circuit breaker can serve as the disconnect if the circuit breaker is within sight from the heater or it’s capable of being locked in the open position [Sec. 424.19(B)].
Unit switch as disconnect ― A unit switch with a marked “OFF” position that’s an integral part of the equipment can serve as the heater disconnect, if it disconnects all ungrounded conductors of the circuit [Sec. 424.19(C)] (Figure 424.19C0 01).
Mike HoltMike Holt
Related
Rawf8 I Stock Getty Images Plus
