Code Q&A: GFCI Protection for Pool Pump Motors
Test your NEC knowledge.
Q. When a pool pump motor is replaced, what does the NEC require regarding GFCI protection?
See answer below.
A. As noted in Sec. 680.21(D), where a pool pump motor is replaced, the replacement pump motor must be provided with GFCI protection.
Mike Holt
Mike Holt
