Code Q&A: PCS Control Settings
Question: A PCS shall include _____ settings capable of being set in amperes for each controlled conductor, controlled source, or controlled load. The PCS control setting shall be considered as a continuous load.
a) automatic
b) control
c) manual
d) user
See answer below.
Answer: b) control
According to Sec. 130.70(A), "The PCS shall include control settings capable of being set in amperes for each controlled conductor, controlled source, or controlled load. The PCS control setting shall be considered as a continuous load."
Ryan Jackson
Ryan Jackson
Ryan Jackson is a National Electrical Code instructor and textbook author in the Salt Lake City, Utah area. He is also a technical consultant for the Steel Tube Institute. He is a member of Code-Making Panels 3 and 17 for the National Electrical Code and serves on several technical committees for UL Standards and Engagement. He is certified as an inspector in electrical, building, mechanical, and plumbing codes, and has taught the NEC and NFPA 70E at the national level over the last three decades.
