Code Quiz: Rainproof Equipment
What do you know about rainproof equipment?
Question: Per the NEC, is this statement true or false? Rainproof equipment is designed to prevent water from entering the enclosure.
See the answer below.
Answer: False
Explanation: Rainproof equipment is designed so that water will not interfere with its successful operation. Raintight equipment is designed to keep water out. (See the definitions section in Art. 100).
John Lupacchino
Senior Design Engineer
Related
alexeyrumyantsev/iStock/Getty Images Plus
Wiring job
