Code Quiz: Workspace Requirements Near Panelboard
Based on the 2020 NEC.
Question: Can a wireway be installed on the wall below a surface-mounted panelboard if the wireway is deeper than the panelboard?
See answer below.
Answer: Yes
Explanation: Section 110.26(A)(3) of the 2020 NEC permits other associated electrical equipment to extend not more than 6 in. beyond the enclosure into the required workspace.
John Lupacchino
Senior Design Engineer
