Power Quality Products
3-phase UPS The MGE Galaxy EPS 8000 UPS product line now includes a 1,000/1,000kVA model. The online, 3-phase UPS single module system is available with 100% rated continuous bypass and output static switches. Featuring advanced 12 pulse rectifier and inverter technologies to restrict total harmonic distortion to less than 5%, the device interfaces with the industry's leading universal communication
3-phase UPS
The MGE Galaxy EPS 8000 UPS product line now includes a 1,000/1,000kVA model. The online, 3-phase UPS single module system is available with 100% rated continuous bypass and output static switches. Featuring advanced 12 pulse rectifier and inverter technologies to restrict total harmonic distortion to less than 5%, the device interfaces with the industry's leading universal communication protocols and incorporates four communication slots in a rack-mount multi-slot cans to support SNMP, J-Bus/ModBus, and RS232-RS485 protocols.
APC by Schneider Electric
Circle XXX
UPS
Part of the Powerware Series, the 5130 UPS line features 1,250VA to 3,000VA line-interactive models designed to protect routers, switches, and workstations, as well as VOIP and EDGE/3G/WiMAX wireless networking equipment. Available in 2U and 3U rack and tower configurations, the UPS includes user-replaceable hot-swappable batteries. For applications requiring longer run times, 2U external battery modules can be added to provide additional hours of backup time.
Eaton
Circle XXX
Tower UPS
The HP Tower UPS models T750G2, T1000G3, and T1500G3 offer power ratings of 750VA, 1,000VA, and 1,400VA. Featuring a line-interactive design with buck and boost regulation, the units also includes an intuitive front panel display, enhanced battery management, prioritized shut-down of attached devices during an electric utility power failure, hot-swappable batteries, network transient protection, and serial and USB ports.
Hewlett Packard
Circle XXX
Backup generator
Unlike fuel-based generators, the Power-Tower battery-powered backup generator can be installed or set up indoors. In addition, the system can be configured to automatically switch on when normal power is lost, or serve as a portable power source. According to the company, the unit can provide backup to multiple circuits at power levels equivalent to normal service.
Gaia Power Technologies
Circle XXX
