PQ recorder
PQ recorder
The 1760 3-phase power quality recorder is designed to comply with the IEC 61000-4-30 Class-A standard. This PQ recorder allows the user to customize thresholds, algorithms, and measurement selections. It has a 2 GB internal compact flash memory and features 10 MHz, 6,000Vpk waveform capture. It analyzes a range of parameters including: rms values; flicker; voltage dips; voltage swells; voltage unbalance; current and voltage harmonics to the 50th order; interharmonics; THD; mains signaling; reactive power; transients; and power factor.
Fluke
For more information, visit www.fluke.com.
