Watertight Receptacles
IP66-compliant, these watertight receptacles provide wet location protection — even in 1,000-psi water spray, according to the company. Features include a spring-loaded lift lid cover, multipoint watertight sealing surface, and corrosion-resistant components, such as nickel-plated contacts and terminal assemblies, as well as stainless steel mounting screws. Select configurations are available in duplex style.
Related
