NFPA 70E General Requirements for Electrical Safety-Related Work Practices, Part 4
NFPA 70E requires investigating electrical incidents and near misses, maintaining a compliant lockout/tagout program, and documenting three types of audits.
Key Highlights
  • Investigate electrical incidents and near misses to identify hazards and prevent recurrence.
  • Include a lockout/tagout program that complies with NFPA 70E 120.2(A), or reference the employer’s compliant program.
  • Document an electrical safety program audit at intervals no longer than three years.
  • Conduct and document field work audits annually or more often as needed.
  • Audit and document the lockout/tagout program, training, and field execution annually or more often as needed.
Section 110.3 of NFPA 70E provides the general requirements for an electrical safety program. It concludes with three short subsections.
Subsection (J) addresses incident investigations by requiring the electrical safety program to include elements to investigate electrical incidents. The Informational Note says such incidents not only include those that resulted in fatality, injury, or health damage but also those that could have resulted in such outcomes. A “could have is often called a “near miss”. What separates a near miss from an actual? Pure luck. If you conduct an investigation into the factors that produced a near miss and can correct for those factors you stop relying on luck. For example, Bob caused an arc flash between two DMM probes but nobody got hurt. Bob reported the flash, and it turned out he was trying to apply both probes at once. If everyone gets trained on proper probe application technique, you no longer need to rely on luck to prevent the arc flash that results in an arc blast that would have killed Bob and three other people.
Subsection (K) is also very short, despite being titled “Lockout/Tagout Program.” That’s because it’s a general requirement. It requires one of two things:
  1. A lockout/tagout program that complies with 120.2(A) (which is where all that “missing” detail is).
  2. A reference to the employer’s lockout/tagout program that complies with 120.2(A).
Subsection (L) is about auditing. You need three types of audit, and each of them must be documented:
  1. Electrical safety program audit. Purpose: To verify that the principles and procedures of the electrical safety program comply with NFPA 70E. This audit must be performed at intervals not exceeding three years.
  2. Field work audit. Purpose: To verify that people in the field are following the electrical safety program’s procedures and principles. This audit must be performed annually (or more often, if necessary).
  3. Lockout/tagout program and procedure audit. Purpose: To identify and correct deficiencies in the program itself, the training, and execution in the field. This audit must be performed annually (or more often, if necessary).
