Hint: No way out
Can you see the door that’s hidden behind all these appliances being stored in this electrical room? That door is the only way in or out of this room. I opened the door and climbed over all the appliances so I could capture this scene.
Section 110.26(B) clearly states that the working space required for this electrical equipment shall not be used for storage. I don’t think the maintenance guy for this apartment complex has ever read the NEC. In fact, this is a very common problem found in electrical rooms of all types of occupancies.
In addition, Sec. 240.24(A) requires circuit breakers and switches containing fuses to be readily accessible. Nothing in this electric room is readily accessible. In an emergency, this could result in disastrous consequences if these switches and circuit breakers cannot be reached quickly. Property owners and managers need to need to be proactive in preventing situations like this from arising.
Russ LeBlancRuss LeBlanc
