Luminaires (Indoor – Surface Mount, Suspended & Wall Mount)
48. Cooper  Lighting: Corelite Loft Micro LED Luminaires The crisp,  modern profile of Corelite’s Micro LED series is the first high performance  true Direct/ Indirect LED fixture.  With  industry leading, patent pending technology, the Loft Micro LED ...
The crisp, modern profile of Corelite’s Micro LED series is the first high performance true Direct/ Indirect LED fixture. With industry leading, patent pending technology, the Loft Micro LED series maintain the elegant and modern style of its fluorescent counterparts with a dramatic 17% reduction in power consumption. Available in two micro-profile styles with two different lens media, the Micro LED series is ultimate showcase for Cooper Lighting’s new ALM LED module. The proprietary LED platform delivers a soft, diffuse volume of pure white light on both task and ambient surfaces with a guaranteed system life of 50,000 hrs. The Micro LED suspended fixture may be mounted individually or continuously with 4 ft, 8 ft and 12 ft modular sections and are perfectly suited for any application with demanding aesthetic and performance considerations. Available in 3000K, 3500K and 4000K CCT with an 85 CRI, a Frosted Prismatic lens offers a soft appearance (resembling fluorescent) or a Clear Micro Prismatic lens provides a unique “zipper” light pattern while providing no glare.
Important Links:
Corelite Loft Micro LED Luminaires Microsite
Corelite Loft Micro LED Luminaires Brochure
49. Lithonia Lighting: STLED - Surface Volumetric LED
STLED by Lithonia Lighting, an Acuity Brands company, delivers a high level of performance, design and user simplicity, and is considered the most advanced surface-mounted luminaire for general ambient lighting applications. A high-efficacy light engine delivers long life and excellent color, ensuring a superior quality lighting installation that is highly efficient and sustainable. STLED's innovative design complements other LED recessed volumetric architectural products from Acuity Brands to achieve a coordinated visual appearance. End caps are available in standard and custom finishes. STLED's high-efficacy light engine delivers long life and excellent color. It reduces maintenance costs and downtime compared to standard fluorescent's. The luminaire is rated to deliver L80 performance for up to 50,000 hours of light with less than 30 percent lumen depreciation. It also improves overall productivity by eliminating lamp replacement. Acuity Brands nLight embedded controls can be installed and are used to continuously monitor system performance, allow for a constant lumen management/compensation function, facilitate simple plug-and-play network and control upgrading via Cat-5 cabling. Full-range (0-10V) dimming is also standard. The STLED is available in surface, stem and suspended mount configurations.
Important Links:
STLED - Surface Volumetric LED Product Specifications
STLED - Surface Volumetric LED Microsite
50. Lutron Electronics Co., Inc.: Stairwell Retrofit Solution
The Stairwell Retrofit Solution is an energy-saving lighting solution that combines the PowPak stairwell fixture and Radio Powr Saver wireless occupancy sensors. The fixture utilizes a Lutron digital dimming ballast that has pre-programmed occupied and unoccupied light levels that are field-adjustable and specific to a project’s code requirements. The occupancy sensors send signals to the fixture via Lutron reliable Clear Connect RF technology, automatically adjusting light output based on the occupancy of the stairwell. This solution provides the ability to assign multiple fixtures to a single sensor and/or multiple sensors to a single fixture. Since the occupancy sensor is not integral to the fixture, the Stairwell Retrofit Solution provides the flexibility to determine the number of sensors, mounting configuration and placement requirements based on the stairwell design. Wireless communication between devices makes retrofit installation simple, allowing the sensor(s) to be mounted in the location that provides the maximum area of coverage with no need to add/move wires. The PowPak stairwell fixture is available in 2, 3, or 4 ft., and 1 or 2 lamp models. Lamp options include T8, T5HE, T5 HO and reduced wattage T8. Radio Powr Saver wireless occupancy sensors offer enhanced passive infrared sensing with Lutron XCT technology and are available in ceiling, wall, hallway and corner-mount configurations. PowPak stairwell fixture, MSRP: $390. Radio Powr Savr occupancy/vacancy sensor, MSRP: $85 - $130
Important Links:
Stairwell Retrofit Solution Microsite
Product Specification Submittals
Product Literature
