Compact band saw
Compact band saw
The X-Band saw uses an 18V rechargeable battery to cut through copper, galvanized and black pipe, conduit, PVC, and wood as wide as 2.5 in. The 8-lb saw requires just one hand to operate, freeing the other hand to guide material through the saw and ensuring an accurate cut. It also comes equipped with a 21,000-rpm motor, a bi-metal blade, and a quick-change blade release.
Stout Tool Corp.
For more information, visit www.stouttool.com.
