The Silent Curse of Botched Repairs
Generally, you can classify a botched repair as either incomplete or incorrect.
A repair is complete only when the reasons for the repair have all been addressed. For example, a motor failed. An incomplete repair consists of simply replacing the motor. A complete repair consists of identifying the cause of the failure and solving it (e.g., voltage imbalance caused it to overheat).
An incorrect repair is one with errors. For example, a blown 2A fuse was replaced with a 10A fuse because that's what was available. A common type of incorrect repair is the introduction of contaminants into a system. This usually happens due to a combination of poor work habits and poor working area hygiene.
Identify reasons you can address. A repair may be incomplete due to time pressure, parts unavailability, poor scope definition, poor training, poor procedures, or poor attitude. A repair may be incorrect for the same reasons it would be incomplete, but to the list you can add parts damage from poor storage practices, poor diagnosis, poor work habits, poor work area hygiene, poor plant hygiene, worker inattention, and incorrect post-repair testing.
Mark LamendolaMark Lamendola
Related
Plant Workers Taking A Break Dreamstime Xxl 86406443
Success and failure
