Automate a Follow-Up
Develop a chart of failure modes and a list for each one.
Sometimes when a repair is made, some undetected problem remains. A repair tech might monitor the equipment briefly after re-energizing, but this is not enough to reveal the time bomb. The problem may not be one that preventive maintenance (PM) would reveal either, so simply scheduling a PM for a few days after the repair is no solution. That also consumes time, as does requiring a PM to be performed as part of the repair job.
The way you catch this is to develop a chart of failure modes. For each failure mode, list potential collateral or parallel damages. For example, if a motor drive fails due to a transient voltage spike, then parallel damage would be motor insulation damage. When a given failure mode is entered into the repair log for this equipment, a work order is generated for checking those collateral or parallel damages.
With this method, you aren’t wasting time performing irrelevant testing or inspection. However, you are looking for precisely what might cause additional downtime without slowing the original repair.
