Tools for Analyzing and Planning
The CMMS can be a fantastic tool for analyzing and planning, yet it is often used merely as a work order system. A modern CMMS allows you to slice and dice data in ways that provide insight into potential trouble or improvement. Explore the various reports your system can generate, and you will see not only questions you hadn’t thought of, but also the answers.
At one time, every CMMS relied on manual data entry (usually from paper forms). Today, we have DMMs that can wirelessly transmit measurements to the CMMS. Even better, we have a variety of sensors that can supply condition data between PMs. For example, you can equip every motor in the plant with wireless vibration sensors. The cost “could” be a reason not to do this if downtime for a given motor isn’t costly, but why not be able to see the vibration status of all motors at a meta level? At a glace, you can tell that all the motors are fine except one is showing signs of trouble.
Mark LamendolaMark Lamendola
Related
Group Of Engineers On Site
dreamstime_l_130445275
