Fix Frustration Factors — Part 2
Frustration factors not only add time to repairs, but they also drive good employees away. The following are some common ones and what to do about them:
- Spare parts are not there. Set a min/max. Outsource consumable min/max to a local supplier.
- Spare parts are there but not serviceable. Determine the proper storage method for each spare. If you can’t accommodate it, don’t store it.
- Operator with an attitude problem. Encourage a “we are in this together” mentality on both sides.
- Department manager pestered repair tech. A good manager knows better than to keep asking “Are you done yet?” Make sure other managers follows this lead.
- Instruction manual was missing. Try to store all manuals digitally and make them available wirelessly.
- Incomplete drawing package caused preventable errors. Ensure every drawing package has an index of drawings so the user can easily see what is missing.
- Lack the proper tools or instruments. Going cheap here is false economics.
- LOTO was too much unnecessary hassle. Investigate any such complaints for engineering solutions.
Mark LamendolaMark Lamendola
Related
Frustrated Engineer At Construction Site Benjawan Sittidech Dreamstime
Engineer And Tech At The Plant Yurii Zushchyk Dreamstime Xxl 186993149
