Unsafe Conditions When Running Raceway — Part 7
Running raceway can be physically exhausting, especially if it is large diameter conduit or if you have to climb up and down ladders as you go. Keep in mind that you are not expected to be a world-class endurance athlete. Even if you are in excellent physical shape, there is only so much gas in your tank.
If you feel fatigue coming on, ask your supervisor for a different task to do for an hour or so while your back and shoulders recharge.
Better yet, assess the situation ahead of time and plan blocks of time in which you alternate between overhead work and something else. For example, suppose Jim bends conduit while you and Gary install it overhead. Every half hour or so, one of you switches with whoever is at the conduit bender. Or, you run raceway for about an hour, do a wirepull (if there is one ready to do), strip and terminate conductors for about half an hour, and then run raceway for about an hour.
Don’t try to outlast fatigue.
Mark LamendolaMark Lamendola
