Unsafe Conditions When Running Raceway — Part 6
Raceway is often run in an existing, operational facility. For example, a manufacturing plant installs a new machine and needs a branch circuit added. Part of the job may entail running raceway to an existing panel that contains energized circuits.
Typically, you would be expected to work in this panel while it is energized, under the theory that you’re not going to be working on any energized circuits — you’re just opening the concentric knockout on one wall and threading a locknut onto a fitting you’re pushing through to the inside. What can possibly go wrong?
Here are some tips to stay safe:
- Use insulated tools.
- Use an insulated blanket or similar barrier.
- Wear gloves rated for the voltage you would encounter if you touched a live part in that panel.
- Wear the proper PPE for the energy you will be exposed to while that cover is off (breakers can get hot and explode with no warning).
- Visually inspect for neutral-ground bonds; these can put enclosures at line voltage if a circuit neutral is opened.
Mark LamendolaMark Lamendola
