Don’t Let Repairs Prolong Problems
Seven things to consider before making a repair
Sometimes, it doesn’t make sense to repair equipment. While doing so may be the normal and expected response, it could be the wrong one. Unfortunately, this decision is often delayed until a piece of equipment fails, and the responding tech is under pressure to get it running again. The tech achieves this, but what is the result?
In many cases, the equipment is well past its “expiration date.” Problems may not only include another unscheduled shutdown waiting to happen, but also operating and maintenance inefficiencies that a replacement or upgrade would eliminate. The solution is to plan and schedule a replacement.
How can you determine when it makes sense to schedule a total replacement rather than just repair as needed? Consider the following factors:
  1. Equipment age.
  2. Characteristics of current product offerings vs. what you are using.
  3. Problem frequency history.
  4. Problem cost history, including lost revenue.
  5. Operator complaints.
  6. Parts availability.
  7. Ease of maintenance/repair.
