How Do You Market Repairs?
The maintenance department is a business within a business, which means it has internal customers. Unfortunately, the maintenance department can be a juicy target for budget cuts, since people tend to see it as a cost rather than a provider of revenue.
For example, if important production equipment goes down, then that window of downtime might be mentally associated with maintenance and blamed on repair techs, because the equipment isn’t up and running.
Even if the downtime cause is due to bad material or operator error, the perception could be “we’re down while waiting for maintenance to fix the problem.”
How can you position the importance of maintenance in the minds of internal customers as an uptime recovery resource? Here are three tips:
- Refer to a repair as an “uptime recovery operation,” not “downtime.”
- Instead of discussing how long the repair techs took to get the equipment running, talk about how quickly they recovered the uptime.
- If extended downtime was needed to affect a quality repair, don’t say “extra downtime.” Rather, say “run time extension.”
Mark LamendolaMark Lamendola
