Using Repairs to Get Ahead
Go beyond an internal summary that says repairs are being performed.
Like it or not, every organization has internal politics. How well you play this game affects the maintenance budget (increase versus cut), headcounts (hire versus lay off), and your own career advancement.
It’s not enough to provide a summary that shows your peers and higher-ups that maintenance is keeping the place running. That’s what they expect.
Regularly select a repair to analyze for root causes, and then report on what you did beyond simply make the symptoms go away. Imagine what happens if you generate and distribute a weekly report with something like this in it:
“Jennifer asked us to look closely at the motor she replaced, because its failure caused Line X to stop for two hours. We put her on a team to do that, along with Josh, Jerrod, and Janet. They found and fixed power anomalies in the feeder circuit. Because that’s the main supply to that area of the plant, we should see a downtime reduction of about 18%, which translates to an additional $4.5 million of revenue per month.”
