When a repair has been performed, what does the repair tech do with old parts, leftover fluids, and other materials? Not everything can go into the general waste stream. Sometimes, an item or fluid cannot go into its normally designated disposal container.
- If you replace the oil in the gearbox driven by the motor you just replaced, that oil goes into a special drum for used oil, per EPA regulations. That is, unless you also decided to use trichloroethane or a similar solvent to help clean the reservoir. You cannot dispose of oil thusly contaminated using regular oil drums (unless your company enjoys big fines from the EPA).
- The control cabinet has several small fluorescent lamps, and you replaced one. It has to go to your used lamp storage area for recycling, not into the regular trash.
- Good thing you had a clean rag when you cut your finger. Dispose of it in the biohazard waste container
- Old circuit boards contain toxic metals and do not go into the general waste stream.
Mark LamendolaMark Lamendola
Related
Warning Of Toxic Or Poisonous Substances
Old Fluorescent Lamps Safety Hazard Ligthting
