Collateral Damage
Do repairs in your facility often incur collateral damage? For example:
- Scratched cabinets. Protect surfaces if you do any drilling, clamping, or cutting. Use sharp blades and bits. Cure “drill bit wander” by using a step drill bit.
- Chipped drywall. When replacing switches or receptacles, handle the devices carefully, and don’t use worn screwdriver bits.
- Stained carpet. Your repair required paint touchup in the office. Why didn’t Bob see your paint can as he walked past you? The better question is: Why did you leave it where it might be kicked over?
- Insulation waste. Don’t leave behind the little bits from stripping wire. You can strip over a bucket or drop cloth to catch them, or simply make a point of picking them up.
- Wiring slop. You cut all those tie wraps and looms to perform troubleshooting. Leave the cabinet at least as neat as you found it.
- Old parts, rags, etc., left at the scene. If this is a recurring problem, require “before” and “after” photos of each repair location.
Think ahead to prevent creating messes or more problems.
Mark LamendolaMark Lamendola
Related
Electrician Testing Electrical Equipment
Dreamstime M 2184238
