Code Quiz: Signs with a Retrofitted Illumination System
National Electrical Code labeling retrofit tube LED lighting
When retrofitting signs equipped with tubular light-emitting diode lamps powered by the existing sign sockets, the sign shall include a label ______________.
A) alerting service personnel that the sign has be modified
B) that meets the requirements of Sec. 110.21(B)
C) to include a warning not to install fluorescent lamps, and is visible during relamping
D) All of the above
See the answer below.
Answer: D
There’s a new requirement in Sec. 600.4(B) of the 2017 NEC. It notes the following: When retrofitting signs equipped with tubular light-emitting diode lamps powered by the existing sign sockets, the sign shall include a label alerting service personnel that the sign has be modified, meets the requirements of Sec. 110.21(B), includes a warning not to install fluorescent lamps, and is visible during relamping.
Related
ID 443647925 © Ahmad Yani Bahrom Azhar | Dreamstime.com
dreamstime_xxl_443647925
ID 223092987 © Ahmet Yamak | Dreamstime.com
dreamstime_xl_223092987
