Code Quiz: EMT Serving HVAC Equipment
Can you answer this true or false statement correctly?
Based on the 2020 NEC.
True or false?
Statement: EMT utilizing compression fittings installed outdoors on a roof serving HVAC equipment can be installed without a separate equipment grounding conductor (EGC).
See the answer below.
Answer: False
Explanation: Section 440.9 of the NEC requires a separate equipment grounding conductor (EGC) for EMT with compression fittings installed outdoors on a roof when serving HVAC equipment.
John Lupacchino
Senior Design Engineer
Related
