Code Quiz: Receptacle Requirements in Crawlspaces
Test your NEC knowledge with this challenging quiz question
Based on the 2020 NEC.
Question: Do crawlspace receptacles require GFCI protection?
See answer below.
Answer: Yes
Explanation: All single-phase 125V through 250V receptacles installed in a crawlspace at a dwelling unit require GFCI protection per Sec. 210.8(A)(4). In addition to this, all receptacles, 125V through 250V, supplied by single-phase circuits rated 150V to ground or less, 50A or less, and all receptacles supplied by three-phase branch circuits rated 150V to ground or less and 100A or less require GFCI protection per Sec. 210.8(B)(9).
John Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
