Based on the 2023 NEC.
Question: True or False? In a dwelling unit kitchen, the receptacle supply power for an electric range is required to have GFCI protection?
See answer below.
Answer: True
Explanation: Section 210.8(A)(6) applies to ALL receptacles 125V through 250V single phase 150V or less to ground. This includes the receptacle for the range. The 2020 NEC requirement was only for receptacles that served the countertop surfaces, which would not include the range.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
colorful question mark notes
dreamstime_xxl_166171277
