Based on the 2026 NEC.
Question: What four items are required on an arc flash hazard label?
See answer below.
Answer:
- Nominal System Voltage
- Arc flash boundary
- Available incident energy or minimum required level of personal protective equipment
- Date the assessment was completed
Reference: Section 110.16(A)
Explanation: The 2026 NEC now lists four items that must be provided on arc flash labels. They must also comply with the requirements of Sec. 110.21(B), which requires they be permanently affixed and not hand written.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
Related
dreamstime_m_447728197
