NEW PRODUCTS
Power Control Systems
These power control and synchronizing switchgear systems are designed with low- and medium-voltage ratings for single- and multi-unit on-site power generators. In addition to emergency power, system designs may include peak shaving, load curtailment, and utility paralleling for both open transition transfer and live-source closed transition transfer. The systems also include sensors to monitor volts, amps, watts, frequency, and other pertinent electrical power data of individual generator sets and an overall system.
Russelectric
Hingham, Mass.
Circle 229 on Reader Service Card
Grounding System
Pulserplus is an all-digital, high-resistance grounding system designed to allow industrial process plants to operate at 100% of capacity during temporary ground-fault conditions. Data logging is a standard feature of the Pulserplus, making it easier to troubleshoot and correct faulty process conditions during normal daily maintenance schedules with less emergency or overtime expense.
Post Glover Resistors
Erlanger, Ken.
Circle 234 on Reader Service Card
UPS System
The PureWave UPS system provides backup power for 30 sec at 100% load and up to 60 sec at partial loads. The system uses an offline design in which the batteries are electrically connected only during outages. The expandable system is available in ratings from 313kVA to 1250kVA and 380V to 600V. It also comes with a five-year, 625-megajoule-per-battery-string unconditional warranty on the batteries.
S&C Electric
Chicago, Ill.
Circle 230 on Reader Service Card
UPS Series
The SmartPro 2U series of uninterruptible power supply (UPS) systems features battery backup, automatic voltage regulation, surge suppression, and line-noise filtering. A microprocessor controls all UPS functions and uses an instruction set to monitor incoming power and environmental conditions. All three models (1400VA, 2200VA, and 3000VA) have a slim-line cabinet design that accommodates two units. Other features include an external battery connector, dual-output circuit breakers, and an emergency power-off connection.
Tripp Lite
Chicago, Ill.
Circle 233 on Reader Service Card
Power Conditioner Series
The CX series of power conditioners now includes 2, 3, 5, and 10kVA-rated models. The units are hardwired, single-phase power conditioners with voltage step-down capability. Packaged within a NEMA enclosure, the series features a low-impedance isolation transformer and power conditioning/surge suppression technology with a control panel disconnect.
ONEAC
Libertyville, Ill.
Circle 231 on Reader Service Card
AC Line Reactors
This line of AC line reactors protects sensitive equipment by reducing line problems. The reactors are available from 2A to 600A and 1 hp to 500 hp. Voltage ratings include 208V, 240V, 480V, and 600V at 3% impedance. The 480V and 600V models also are available at 5% impedance. A DIN-rail adapter plate is an option for sizes up to and including 16A. All reactors come with a limited 10-year warranty.
Acme Electric
Lumberton, N.C.
Circle 232 on Reader Service Card
