Electrical safety tester
The Primetest 100 is a battery-powered handheld tester designed to check tools and portable electrical equipment. In addition, the instrument can perform cord polarity tests as well as check that power sockets are wired correctly. Universal graphics on the case of the device guide users through the three test modes available, and a single push-button operation establishes the appropriate sequences for the selected tests. Tests are carried out against preset pass/fail limits, and the large LCD gives a clear pass/fail indication, as well as test values. Supporting PDA-based software also is available, allowing test results to be recorded for subsequent transfer to a PC stored database or other record-keeping system.
Seaward Group USAFor more information, visit www.seaward-groupusa.com/
