Focus on Safety
Tamper-resistant receptacles
These tamper-resistant decorator receptacles are designed to prevent children from accessing electrical outlets without inconveniencing adults or compromising appearance. The receptacles feature a UL-listed shutter system in which a thermoplastic shutter covers access to the receptacle contacts. The contacts can only be accessed with the insertion of two-bladed or grounding plugs — the insertion of a foreign object in any one side of the receptacle will not open the shutter. The receptacles are available in two versions — one with an LED nightlight and one without.
Pass & Seymour/Legrand
Circle 300
Shock-absorbing lanyard
The WrapBax 2 lanyard is designed for tie-back use and features the company's patented snap hooks. The lanyard can be operated with the use of one hand and features 5,000-lb strength requirements. It is lightweight and incorporates an angled head on the hook for easy installation onto webbing. The lanyard also includes heavy-duty, abrasion-resistant 13,000-lb tensile strength webbing and eliminates the need for a separate anchorage connector, reducing inventory and cost.
DBI-Sala and Protecta
Circle 301
Arc flash labels
New stock labels and training aids by this company are designed to enhance arc flash awareness and safety. The new warning labels meet NEC/NFPA requirements for field marking switchboards, panelboards, and motor control centers. The new arc flash stock labels warn of both arc flash and shock hazards and are available in various sizes. Training aids include a poster, sign, label, wallet card, and work permit — all designed to promote safe, compliant electrical work practices.
Brady
Circle 302
Simply Safety PLUS, V3.1
Simply Safety PLUS, V3.1 is a safety software and training program designed to eliminate spreadsheets, Word documents, binders of policies and procedures, and reduce manual file keeping. The software allows users to manage all of their corporate safety and training data in one location and makes all safety data readily available for presentations. In the new PLUS V3.1 version, certificate of recognition (COR) tracking capabilities are embedded into program modules.
KnowledgeWare Communications
Circle 303
Banded earplugs
Howard Leight PerCap banded earplugs are designed for workers exposed to intermittent noise. The folding banded earplugs are semi-aural protectors with soft polyurethane ear pods that seal the opening of the ear canal and offer attenuation ideal for workers exposed to low levels of hazardous noise. The earplug's multiple-position band can be worn under the chin, over the head, and behind the neck of the user. Replacement ear pods are available separately.
Bacou-Dalloz
Circle 304
