Cable connectors
MC Cable Connectors feature a Powr-Lock grounding seal with stainless steel tines that grounds the connector to the armored cable and provides 360° strain relief. The one-piece connectors also have an embedded Viton O-ring that ensures a watertight and corrosion-resistant termination seal. They meet CSA standards for raintight armored cable fittings, are rated NEMA 4 and IP 65, and are available in aluminum, nickel-plated aluminum and stainless steel.
Remke
For more information, visit www.remke.com.
