Transfer switch control
RTS Series 30-cycle-rated and 3-cycle-rated automatic transfer switches feature the company’s RPTCS microprocessor automatic transfer control system. Programmed at the factory to include user-specified options, setup, alarm acknowledgement, and review of data are easily accomplished using the controller’s soft keys and color display. An intuitive, interactive menu guides the user through controller setup and the entering of configuration data, including communications and timing set points, adjustable control parameters (interlocks, alarms, and security), and event logging. In addition, the product supports standard Modbus RTU or available Modbus TCP/IP via 10/100 Base-T Ethernet.
Russelectric
For more information, visit www.russelectric.com.
