4 Things You Didn’t Know an Insulation Tester Could Do
How new insulation testing capabilities are making electrical testing safer, faster and easier to document
Key Highlights
  • Bluetooth-enabled insulation testers allow electricians to control and monitor tests remotely while viewing real-time readings and charts on their phones or tablets.
  • Automatic test logging and PDF or CSV exports simplify documentation, eliminating the need for handwritten reports.
  • Color-coded pass/fail indicators and guided testing workflows help electricians interpret results quickly, avoid setup mistakes and ensure reliable test documentation.
By Greg Anliker, End User Experience Manager, and Chris Forthaus, Senior Product Manager of T&M Equipment, at IDEAL Electrical
Insulation testers, or megohmmeters, help to verify conductor insulation and detect issues such as leakage current. The devices are an important tool to check wiring installations and document test results before energization, especially for those working on large commercial sites such as data centers.
Traditionally, electricians must remain close to the insulation tester during timed dielectric absorption ratio (DAR) and polarization index (PI) tests in order to handwrite their results. The process is often tedious, requiring electricians to observe the display during the test and keep track of paper reports.
Today’s electricians deserve better solutions. We already broke down why electricians should upgrade their tool bags with smarter, tech-driven tools in another article for EC&M earlier this year. Now, let’s dive deeper into four ways insulation testers make testing simpler and faster.
#1: You can control tests and view charts live on your device
Some insulation testers integrate with an app to make controlling and verifying wiring installations more convenient. After downloading the app on their phone or tablet, users typically connect their smart megohmmeter to the app via Bluetooth.
For example, the new Insulation Tester Plus from IDEAL Electrical is integrated with the free Electrician’s Sidekick app. The app mirrors the Insulation Tester Plus’ display and provides users with a graph of their readings that updates in real time as the test progresses. This also means that users no longer need to constantly watch the display during the test to ensure they write down every fluctuation; the app automatically records the test data from the meter.
#2: You can monitor tests from a safe distance
App integration also means electricians no longer need to remain physically near the device during the test. They can instead monitor their test remotely through their phone or tablet.
The advantages of this approach include enhanced safety and convenience. Electricians can set up the megohmmeter with their test specifications, then start and complete the test from a safe distance away using the app’s controls. They can even close the cabinet door with the device inside and remain outside the arc-flash boundary during the test. This means, for example, that changing into hot and heavy PPE gear may not be needed as often (though this is always dependent upon the application and relevant code requirements).
#3: You can export test logs instantly, no handwritten notes required
During traditional insulation testing, electricians must handwrite reports with the meter’s results. The process is both time-consuming and potentially prone to human error. For example, the paper report could get misplaced and require the test to be redone.
With a smart insulation tester, reporting test results becomes much simpler. The app logs all the data collected by the meter. Once the test is complete, electricians can easily export the documentation that their general contractor or inspector requires. For example, the Insulation Tester Plus app allows electricians to export their results as a CSV or PDF file.
#4: You can determine pass/fail test results at a glance
Insulation test results are not always obvious at first glance. But when testing across a large jobsite, electricians need to be able to interpret results quickly and keep moving. Smart insulation testers include features designed to provide an immediate indicator of test results.
One example involves a color-coded display. Once an electrician sets up their testing parameters, the Insulation Tester Plus display lights up green when a test passes and red when it fails. This intuitive display helps electricians work more quickly and confidently by providing instant feedback on test results.
The Future of Smart Insulation Testers
Electricians are increasingly asked to document wiring installations for sensitive projects like data centers, where uptime requirements are strict. As these requirements increase, smarter insulation testers can help electricians keep project timelines on track with faster testing and easier reporting.
The new Insulation Tester Plus from IDEAL Electrical is one such solution. The device’s app integration and other features reimagine the traditional method of using an insulation tester. With this megohmmeter’s patent-pending Workflow Validation System, electricians can:
●    Trust the Result: The Insulation Tester Plus validates measurement quality before accepting the result.
●    Guide the Technician: The Electrician’s Sidekick app walks users through the correct testing sequence and catches setup mistakes.
●    Document the Work: Every valid test is logged with supporting evidence, creating stronger reports and compliance records.
With a color-coded pass/fail display and Bluetooth app integration, smart tools like the Insulation Tester Plus will help transform how electricians work.
Sponsored by:
