What's Wrong Here? Hint: Problematic Wood Paneling
How well do you know the Code? Think you can spot violations the original installer either ignored or couldn’t identify? Here's your chance to moonlight as an electrical inspector and second-guess someone else's work from the safety of your living room or office. Can you identify the specific Code violation(s) in this photo? Note: Submitted comments must include specific references from the 2023 NEC.
Hint: Problematic wood paneling
Tell Them What They've Won…
Using the 2023 NEC, correctly identify the Code violation(s) in this month's photo — in 200 words or less — and you could win a 40-oz. insulated tumbler valued at $39.99, courtesy of ABB. E-mail your response, including your name and mailing address, to [email protected], and Russ will select two winners (excluding manufacturers and prior winners) at random from the correct submissions. Note that submissions without an address will not be eligible to win.
February Winner
Congratulations to our two winners this month. Steve Wallace, an electrical instructor at South Shore Technical High School in Hanover, Mass., and Malcolm Jordan with MDJ Electric Company in Fayetteville, N.C., knew that storing ladders, lights, paint, shelves, and other items in front of a switchboard was a big problem.
Section 110.26 requires working space to be provided and maintained for all electrical equipment so workers can safely work on the equipment. Sections 110.26(A)(1) through (A)(4) establish specific dimensions that are required for working on energized equipment. The minimum working space dimensions would generally be 3 ft deep, 30 in. wide, and 6.5 ft high, but could be much larger depending on the conditions. Section 110.26(B) prohibits using working space for storage. I think Sec. 110.26(B) is written as clearly as any rule in the Code.
Russ LeBlancRuss LeBlanc
