What’s Wrong Here? Hint: Broken Connector = No Grounding Means
Hint: Broken connector = no grounding means.
That broken connector is much more than just a broken connector. It also means the equipment grounding connection has been lost! Section 250.118(A)(5) permits Flexible Metal Conduit (FMC) to be used as an equipment grounding means under certain conditions. However, there are no conditions where FMC will provide an effective ground-fault current path if the connector used to establish that path is broken!
In addition to that violation the broken connector is also a violation of Sec. 110.12(B) since these damaged parts adversely affect the safe operation of the equipment. Where flexibility is necessary to minimize vibrations, Sec. 348.60(B) requires an equipment grounding conductor (of the wire type) to be installed with the FMC to provide reliable grounding and bonding. This broken connector also fails to provide the electrical continuity required by Sec. 300.12.
Russ LeBlancRuss LeBlanc
