Safety: Attendant in Confined Entry
The attendant in a confined entry situation plays a critical role in the safety of those in the confined space. While this job is often characterized by long, boring stretches of “nothing to do” it requires paying attention to what’s going on (or not happening) inside the confined space.
One of the best things you can do as an attendant is stay in constant contact with the crew inside. This doesn’t mean distracting them with a stream of trivial banter; that’s unsafe and inefficient.
Instead, listen for the normal sounds of work being performed. If there’s just silence, ask for a response to a question such as, “Is everyone alright” or “What’s your gas meter reading?” This will also help keep you alert and your judgment clear.
If you sense a problem, don’t rush in to rescue your coworkers. That could easily prove fatal to you, and there would then be no link to the outside world to summon help. If an emergency does arise, first call for help and then confirm it’s on the way. Don’t enter without proper PPE and rescue gear.
