Code Quiz: AFCI Protection in Guest Rooms and Suites of Hotels and Motels
Fill in the blank.
With respect to arc-fault circuit interrupter (AFCI) protection as required in Sec. 210.12, 120V, single-phase, 15A and 20A branch circuits supplying ______ and _______ installed in guest rooms and guest suites of hotels and motels shall be protected by AFCI protection as described in subsections (A)(1) through (6). This applies _______.
A) outlets / devices / to all 120V, single-phase, 15A and 20A branch circuits.
B) outlets / devices / only to those 120V, single-phase, 15A and 20A branch circuits in the vicinity of the bed.
C) outlets / devices / only in large hotels.
D) None of the above.
Answer: A
As noted in Sec. 210.12(C) of the 2017 Edition of the NEC, “All 120V, single-phase, 15A and 20A branch circuits supplying outlets and devices installed in guest rooms and guest suites of hotels and motels shall be protected by arc-fault circuit interrupter protection as described in 210.12(A)(1) through (6).”
Owen is the owner and president of National Code Seminars and the holder of master electrician certifications in 46 states. He can be reached at [email protected].
Related
dreamstime_xxl_409443487
dreamstime_xxl_68499248
