Based on the 2020 NEC.
Question: What is the minimum size required for a plate grounding electrode?
See answer below.
Answer: 2 sq ft
Explanation: Section 250.52(A)(7) of the 2020 NEC requires a plate electrode to expose 2 sq ft to the soil. This can be accomplished with a 12-in. × 12-in. plate, since both sides will be exposed to the soil resulting in an exposed surface area of 2 sq ft.
John Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
red question mark circled by marker
dreamstime_xxl_32651114
